thoughts on a cam
Old Feb 13, 2005 | 07:30 PM
anglia_stang's Avatar
anglia_stang
Default thoughts on a cam
I'm gonna be stroking my 302 to a 331 pretty soon and I'm pretty much sold on which heads and which size injectors to get but the cam is still up in the air. What cam would you guys suggest? I'm thinking the Ford F or E cam or something comparable from another manufacturer. Any thoughts or inputs are appreciated. Thanks
Old Feb 13, 2005 | 07:48 PM
grabbem88's Avatar
grabbem88
Default RE: thoughts on a cam
do not use the abc cams!...........are you going to go pedestal or stud mount?if i was you get the afr high revs from d.s.s.
then go with a n-71 cam from anderson ford.
Old Feb 13, 2005 | 08:58 PM
91LXstanger's Avatar
91LXstanger
whats wrong with the abc cams from ford racing?
Old Feb 13, 2005 | 09:01 PM
grabbem88's Avatar
grabbem88
the duration on the int/exh side being the same.
Old Feb 13, 2005 | 09:17 PM
91LXstanger
oh, so the duration on the intake side should be more, u think?
Old Feb 13, 2005 | 09:48 PM
91LXstanger
wait, i mean the other way around.
Old Feb 13, 2005 | 09:52 PM
grabbem88's Avatar
grabbem88
with afr's,and them being a quick burn style head you would want the exhaust higher on lift,and longer on duration.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jrrhd73must
Oct 2, 2015 09:17 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
