gas smell
Old Feb 14, 2005 | 12:25 AM
lift350's Avatar
lift350
Default gas smell
tonight when i drove my car to the store i got a strong smell of gas inside the car. where should i start to find the problem? it is a 95 gt edelbrock heads, upper and lower intake, fuel pressure regulator, 70mm bbk throttle body, bbk cold air intake with 75mm ProM mass air meter with 24lb injection, 255lph fuel pump. thanks for your help.
Old Feb 14, 2005 | 12:32 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: gas smell
Start with your gas cap.
Do you have an off-road midpipe by any chance?
Old Feb 14, 2005 | 01:54 AM
lift350's Avatar
lift350
no it does not have an off-road mid pipe
Old Feb 14, 2005 | 02:35 AM
Vizaracer's Avatar
Vizaracer
also, check under the car to see if there has been any fuel that has leaked down on the ground. that could help you pin point the probably possibly. also check all carpet (feeling it) to see if it is wet or damp from gas. that will help you find the problem.
Old Feb 14, 2005 | 12:53 PM
roundman's Avatar
roundman
look under the hood and check the fuel lines to see if there is any sign of a leak anywhere first.
Old Feb 14, 2005 | 07:01 PM
vfast's Avatar
vfast
I ♥ Acer
look for any wet spots on the lines and connections....it just takes 1 drop the fill the car up with gas smell....this is nothing to let go on...
Old Feb 15, 2005 | 05:27 PM
Choppa's Avatar
Choppa
i have seen a lot of cases that the rubber grommet around the hole in the gastank and the hose that you put the gas in at the station falls apart. mine just practically gone id check that its like a 20 dollar rubber thing and about 30 mins to put in
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
