operating temperature?
Old Feb 14, 2005 | 10:46 PM
Wildhorses's Avatar
Wildhorses
Default operating temperature?
I just bought a 1997 mustang with a v6. The temperature gage stabilizes past the halfway point just a hair over the 2/3 point. Is this normal? Thanks..
Old Feb 14, 2005 | 10:50 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: operating temperature?
anyhting b/w the C and H is normal. if it goes past the hot martk, turn off the car immediatley though. you dont want any overheating. maybe you need to check radiator fluid or other fluids to see if you are lubed enough.
Old Feb 14, 2005 | 11:02 PM
Wildhorses's Avatar
Wildhorses
Thanks for the reply. I think I'll flush the cooling system as previous owner may not have done this in awhile.
Old Feb 14, 2005 | 11:14 PM
AtlanticBlue99
I ♥ Acer
when buying a used car it is always good to drain and change all oils and lubes b/c like you said, you dont know how the previous owner treated the car.
Old Feb 15, 2005 | 04:20 AM
FoxGT's Avatar
FoxGT
My old coolant looked like mud.
Old Feb 15, 2005 | 12:27 PM
import slayer's Avatar
import slayer
That's why it's nice to have machanical gauges.
Old Feb 15, 2005 | 05:06 PM
Choppa's Avatar
Choppa
i have a 95 v6 and mine runs at about half and sumtimes about 2/3 too. i changed all the fluid and do it regurlaly the mechanic said it was runnin at a safe temp so its fine
Old Feb 16, 2005 | 08:48 PM
stock_95gt's Avatar
stock_95gt
My temp gauge never even gets to the halfway mark. Maybe it's broke? It does move.. but never more than about 1/4 the way on the meter...
Old Feb 20, 2005 | 02:54 AM
Ezrider's Avatar
Ezrider
you probably just have an hotter thermostat, bad or low coolent if it remains the same after flushing the cooling system and it bothers you then go ahead and replace the thermostat with a colder one
Old Feb 23, 2005 | 03:48 AM
Whitecomet25's Avatar
Whitecomet25
My Stangs temp range is between 180 and 200 Fahrenheit. That is why I got mechanical gauges, there help me.
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
svfetter
Oct 5, 2015 11:39 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
