Engine codes?
Old Mar 2, 2005 | 04:59 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Engine codes?
ORIGINAL: GTron
ORIGINAL: luckythirteen13
i went to one autozone and because i have a '92 and no obd2 port, the refused to do it. is that the commen rule or were they just d*cks?
You can check your own with the 92. Not 100% sure about the 94 though. I don't have the exact steps to do, but you just need a jumper wire and a test light. Do a search and I'm sure you can find it.
[/quote]
Don't remember how to retrieve codes off of OBD-I vehicles. Usually a dash light flashing morse code 'tells' you what the code is then you have to translate the code. I don't know on the Mustangs how to get them into trouble shooting mode...
96 and newer vehicles are required to be OBDII compliant and thus have ports, anything prior was OBDII w/ w/o ports or OBDI. here's a link to show which cars in the 94-96 years were inbetweens...
http://www.obdii.com/connector.html
Old Mar 2, 2005 | 05:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 94droptop
My check engine light is on? Is there any auto parts store that will run the codes for me or is there a way i can do it? does anyone know a product or technique to remove surface scratches? would this ebayunderdrive pulley work for my 94 lx vert( how big of a hp increase and how hard is it to put in?
Actron CP9015 should do the trick for about $35. Pep Boys and I think Autozone sell Actron. Depends on the depth of the scratch. surface scratches can be polished out using 'gritty' POLISHING' compound, not to be confused with rubbing compound. HP increase would be 5-7hp tops. Level of diffculty..don't know. Never done it myself.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
