Interesting Electrical Problem
Old Oct 8, 2007 | 11:52 PM
UFGatorNation's Avatar
UFGatorNation
Default Interesting Electrical Problem
Hey guys, wondering if anyone has any ideas on this one.........Went to go start my 91 stang and when I turned the key the idiot lights were kinda dim, and sure enough when I went to turn the key all the way, it clicked and I thought I had a dead battery.
So, I turn the key off and just because everyone has to try more than once, heehee I turn it again and my dash light are as bright as they should be, but when I go to start, nothing.....the dash goes dark.
So I get the other car and try for a jump, this is where it gets interesting.....
When I turn the key again, my lights come on and then everything goes dark, I turn the key back off and then on and the lights are really dim again, So just from getting frustrated, I tap the side of my instrument cluster, next to the headlight switch and my lights come back on, and then my instrument cluster lights come on, like I turned the headlights on, and then go out.
So now I try to crank again and nothing.....the dash lights come on and look bright but no joy. I hear the clicking when I try to crank. Hook up the volt meter and sure enough 12.5 I think I have a short someplace, or possibly a bad ignition switch, So thats where I am going to start tomorrow, just wondering if anyone has had any experience with this one? I know the previous owner had issues with the spedo and had the instrument cluster out and may have damaged the circuit board on the back, so that may be the problem also, ahhhh what fun electrical problems are! Thanks for any input guys!
Old Oct 11, 2007 | 05:22 PM
UFGatorNation
Default RE: Interesting Electrical Problem
Well I replaced the Starter Solenoid and got the car to start ok, so thats a start. I think there may be a short in my guage cluster that I will have to replace, it needs it anyway. No other Ideas from anyone??
Old Oct 12, 2007 | 07:53 AM
99_GT's Avatar
99_GT
Sounds like a loose or bad connection. I would look at the headlight switch. Is it loose or feel sloppy? Thenlook at the cluster wireing. How do the lights act now, after the new solinoid?
Old Oct 12, 2007 | 09:36 AM
Gary H's Avatar
Gary H
Does that year have an instrument voltage regulator? Might look online and see. Also, check the voltage at the battery when you crank it over. Are the lights fine when the car is running? Check the battery cables to, ground cable might be loose or corroded.
Tivo304
Aug 28, 2023 12:19 PM
5.0muscle
Jan 11, 2016 01:17 PM
TfcCDR
Sep 14, 2015 12:08 PM
ernesto-619
Sep 10, 2015 01:32 AM
cbird1177711
Sep 3, 2015 08:43 PM
