squeekin@!
Old Feb 23, 2005 | 01:57 AM
redmustang's Avatar
redmustang
Default squeekin@!
I noticed a squeeky noise coming from my right front of the car when i turn the steering wheel back and forth a little. It does not squeek on the left, only the right front. Any idea what this could be? My car was wrecked on that side, and i had the work done at Ford. I know i have a warranty on the work, but not sure what it is or if it's worth it to fuss about it.
Any ideas/ suggestions?
thanks
Old Feb 23, 2005 | 03:04 PM
fastmustangs1's Avatar
fastmustangs1
Default RE: squeekin@!
Something need to be greased like a bushing. Maybe you have a wheel bearing going out.
Matt
Old Feb 23, 2005 | 11:09 PM
redocmach1's Avatar
redocmach1
i have the exact same problem...but i didnt crash...so i probably have to grease my bushings?
Old Feb 24, 2005 | 01:17 AM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
i (99 v6) and my brother (96 v6) have the same problems, turn wheel all the way to right and it squeaks, to the left- nothing...[:-]
Old Feb 24, 2005 | 02:41 AM
fastmustangs1
It could be the power steering unit itself.
Matt
Old Mar 2, 2005 | 02:41 PM
InfernoKron's Avatar
InfernoKron
Had something similar to that happen on my 96 T-bird, figured out after it went out that the upper ball joint had lost it's grease and eventually it just fell apart, it got quite a bit worse than just squeaking eventually but that's something else to check. Does your car pull one way or the other when braking or just driving or anything? The T-bird used to pull hard left when u braked cause of the ball joint, the bearings were also shot on that wheel though heh.
Blackvenom01
SVT Forums
Mar 7, 2008 02:40 PM
00blackstang
Nov 29, 2007 02:15 AM
im_stuck_in_iraq
Jan 21, 2006 05:08 PM
boostedgt02
Aug 16, 2005 05:09 PM
