please help engine skip
Old Oct 15, 2007 | 12:07 PM
Brian47p's Avatar
Brian47p
Default please help engine skip
i have a 1991 lx v8, 5 speed. The car seems to have very little power and somewhat bucks when i step on it. the car runs great for about 10-15 minutes but once it hits running temp it goes nuts and idle drops and hovers from 400-600 rpms and the car shakes. when i drive it feels like i am bucking the tranny but i am not its just a real loss of power at low rpms, then when i step on it, it bucks until about 3500 rpms and the horsepower kicks in. anyone know anything? my cats may be gone could this be the problem? clogged maybe? the ignition seems to all check out and there are no codes coming up on the computer.thanks.
Old Oct 15, 2007 | 10:39 PM
94Blk5.0's Avatar
94Blk5.0
Default RE: please help engine skip
Post this question in the 5.0 section. Somebody will be able to explain it better than me.
Old Oct 16, 2007 | 12:20 AM
butch86's Avatar
butch86
have you changed anything on your vehicle recently? could be a bunch of things, clogged cat converter,fuel pump going ,a bad ground, iac taking a dump on ya. vacuum leak
Old Oct 16, 2007 | 02:18 PM
Brian47p's Avatar
Brian47p
iac, and grounds are all good cats may be clogged, it feels like they are because itfeels like it blasts out wen i step on it. i was just lookin for some opinions to see if that could cause my problem. car just has cold air and flowmaster mufflers as mods.
Old Oct 16, 2007 | 06:26 PM
capri_83's Avatar
capri_83
pull the vacuum line off the fuel pressure regulater.........turn key on and see if any fuel isat fitting or leaking out......if so it needs a new reg..........and cats most of the time let the car run at idle fine but will have no powerat higher RPM sometimes will not even rev up(if plugged)......just something to check.....
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
