shift kit
Old Feb 23, 2005 | 05:17 PM
hawwk11's Avatar
hawwk11
Default shift kit
Back to shift kits,
How do they work? i have a auto gt and want to know if i put a shift kit on does it work automaticly or will i need to flip switches. will i get 2nd gear chirps with one.
thanks
Old Feb 23, 2005 | 08:32 PM
91LXstanger's Avatar
91LXstanger
Default RE: shift kit
https://mustangforums.com/m_399152/tm.htm Check out the 2nd post "Valek" did on this post. Its ur answer.
Old Feb 23, 2005 | 08:55 PM
luckythirteen13's Avatar
luckythirteen13
he also has 3.73's though. a shift kit will increase the speed at which the trans shifts. the shifts will also be firmer too. when my aod shifts, it slams the gear and jerks the car forward. im still running the stock rear gears and dont notice the tires chirp to much
Old Feb 23, 2005 | 09:23 PM
thelast50ho's Avatar
thelast50ho
A shift kit make you cars shifts firmer by raising hydralic line pressure ans flow in your tranny
Old Feb 26, 2005 | 10:11 PM
janine's Avatar
janine
ORIGINAL: hawwk11
Back to shift kits,
thanks
I have a shift kit installed in my 02 GT, it is an aode. You will feel all shifts and downshifts a lot harder and firmer. Chirps will be stronger. One thing that I find a little anoying is the clanky downshifts at 40mph. Ford aode's are natually clanky when downshifting. The shift kit will bring this out and it will sound as if something is wrong, but it is not. You will have to get used to it. But as far as preformance, it will give you that.
Old Feb 26, 2005 | 10:32 PM
ceyko's Avatar
ceyko
ORIGINAL: janine
Janine, did you modify your tranny at all prior to the shift kit? How does the AODE hold up for you? ( I have an '03 GT AODE...just interested)
Old Feb 26, 2005 | 10:43 PM
janine's Avatar
janine
ORIGINAL: ceyko
ORIGINAL: janine
Yes. I had a 10" 2600 rpm stall torque converter, wide ratio plantary gear set, valve body modification , shift kit and standard freshen up done all at the same time. The AODE holds up well under all power loads. My only grip is it doesn't downshift into passing gear all the time. The transmission guys said "we can tell it how to shift, but we can't tell it when to shift." That is it.
Old Feb 26, 2005 | 10:45 PM
ceyko's Avatar
ceyko
That sux. What was the estimated cost of all your tranny work? (If that is something you don't want to disclose...I understand.)
Thanks,
Ceyko
Old Feb 26, 2005 | 10:56 PM
janine's Avatar
janine
ORIGINAL: ceyko
Thanks,
Ceyko
$2300. That included a cooler and 3 year warranty. This was done at Fred Brown Performance transmissions in Bayshore New York. They are one of the best in the NYC/Long Island area.
Old Feb 26, 2005 | 11:11 PM
ceyko's Avatar
ceyko
Dang, IMO that was a good investment for sure. Thanks for the information.
Ceyko
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
