auto shifters
Old Dec 1, 2007 | 09:59 AM
Cryptostorm's Avatar
Cryptostorm
Default RE: auto shifters
so your saying that you couldn't fix your clutch problem, so your remedy was to replace the tranny and weld a shifter onto the new tranny's shifter????
it would have been a whole lot less involved if you would have just fixed the clutch.... it would have been cheaper even if you would have taken it to a shop
Old Dec 2, 2007 | 10:09 AM
blstoff's Avatar
blstoff
I had a little trouble finding it again too . here's the link . they sell the shift **** & O/D button either as a kit or seperate , make sure you get the kit , its a little cheaper . it's the 6th item from top , part # 1059-kit .
http://uprproducts.com/shopping/shop...ed+Shift+*****
ORIGINAL: m260gt
I like that one too. i looked for it on the website. couldn't find it. do you have the link?
ORIGINAL: blstoff
I got mine from UPR Products . heres a photo....
[IMG]local://upfiles/45178/D8F015BE0CC742E4B18EC51482EF6B0E.jpg[/IMG]
Old Dec 2, 2007 | 12:26 PM
65coupe88hatch's Avatar
65coupe88hatch
GokuRen couldnt u have just used the same shifter? Does an auto mount like a stick?
Old Dec 3, 2007 | 08:45 AM
m260gt's Avatar
m260gt
ORIGINAL: blstoff
ORIGINAL: m260gt
ORIGINAL: blstoff
thanks man. was that hard to install or anything? because im thinkin about getting it. would probably look better if it was billit. But my intrument panel is black so hopefully it will look good.
Old Dec 8, 2007 | 01:43 PM
GokuRen's Avatar
GokuRen
ORIGINAL: 65coupe88hatch
no i couldn't have used the same shifter. the auto shifter i had was broken anyways. and the 5spd shifter bolts to the trans. the auto shifter bolts to the body, and has a cable that links it to the trans.
Cryptostorm Date 12/1/2007 7:59:16 AM so your saying that you couldn't fix your clutch problem, so your remedy was to replace the tranny and weld a shifter onto the new tranny's shifter????
__________________________________________________ _______________________________
No i couldn't fix the clutch problem. There is a crack in the firewall, where the firewall adjuster was. Everytime the clutch was pressed in, it would flex and pry on the firewall. I had the firewall welded and reinforced. BUT, the clutch wouldn't engage properly. The clutch cable would bind and rub against the firewall and the inside of the adjuster. Which caused the clutch to be 100x harder to push, which put more stress on the firewall. After trying to fix the firewall and clutch problem, for about 2 months. I had taken it to multiple body shops, and nobody wanted to work on it. The firewall was damaged too far, and if everything isn't lined up properly, the problem will keep coming back. Various different attempts, nothing worked. So, the ultimate and permanent fix, was to put an Automatic transmission in the car, which cost me absolutely nothing, and was done in a weekend. My brother recently totaled his 5.0 AOD, and bought a 5.0 5spd, and he gave me his transmission and various AOD parts. And, with a 5spd shifter, and a AOD shifter that didn't work, i cut both, and created 1 that worked. Problem solved, and it confuses the hell out of people and i love it. :-D
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
2poor4u2
Sep 26, 2015 11:08 AM
