car whines with rpms
RE: car whines with rpms
No no no!!! the whining doesn't get louder as you turn up the radio, it get's louder the harder you accelerate! lol. Geesh, pay attention ya'll :P. It has happened, so don't make me sound like an idiot :P. I don't have an after-market stereo, so it could still be that. If you check the fan belts and they're fine take it to Best Buy.
If the problem is from the radio, the problem is an electrical intereference. As the RPMs increase, it increases the ground. A ground isolator kit (available at WALMART or radioshack) will eliminate the squeal. It is some sort of interferance between the alternator and radio. Otherwise, other problems could be the belt. New Dayco belts will have the whine, as well as several other brands, until the seat into the v's. You can also check the pulleys to make sure they arent going out. If the problem only occurs when you are moving, I would look more towards the transmission or rearend. I've also heard of throwout bearings on a manual transmission giving off a heck of squeal.
ORIGINAL: Dbeck002
for me? its definately the alternator, it only started after i installed my new 3G alt which i can clearly hear whining. I LIKE IT THOUGH lol...
it could be a million thing where is the noise comming from? my cam wined untill i put a new one it. i dont think it is the sterio i think it might be a little more machanicaly related.
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
