oversized valves?
Old Mar 8, 2005 | 10:59 PM
angcobra's Avatar
angcobra
Default RE: oversized valves?
look a little further down on the spec sheet for duration @.050 = 236/240 this is the numbers normally used when talking about duration. You should be okay on vacuum with that cam. As far as carb, alot of that depends of final HP, you should be able to look at some of the carb websites for a table of hp sizing of carbs.
I am glad you are learning, better to learn the basics. Some never do and just use buzz words and phrases they have heard.
Old Mar 8, 2005 | 11:10 PM
vfast's Avatar
vfast
I ♥ Acer
ok a 650 would be the biggest carb for this....remember this bigger isn't always better
Old Mar 9, 2005 | 07:56 PM
mkspeed26's Avatar
mkspeed26
ORIGINAL: vfast
ya, dont want it to run lean. i saw a lot of crate engines that had similar specs to my engine (specifically the performer rpm 350 crate engine) that have an 800 and it says next to the part description that 750s and 800s are suggested. carb calculator says to get a 700 with 100% volumetric efficiency. edelbrock claims about 96-103% (dont remember exactly, but somethin like that) for the performer rpm manifold. i might try to find a 670 holley street avenger carb. that looks like it would work.
Old Mar 11, 2005 | 06:29 PM
83GT306's Avatar
83GT306
First off dude, stay away from that jimmy carter 800 carb, get a holley dbl. pmpr....750 would be fine.
I was running a 750 Edelbrock carb on my 306 for a while, I thought it was too big, but was told that the Edelbrocks run a little small for the cfm rating in the first place, even so, my engine never ran right, not even with 2 different tuning kits.[:'(]
Threw on a 650 dbl. pmpr. and fixed that noise.
Now she runs marathons.
I'm a spelling nut...
Old Mar 12, 2005 | 06:59 PM
mkspeed26's Avatar
mkspeed26
ORIGINAL: 83GT306
the EPS 800 is an edelbrock carb. doesnt really matter though, im goin with a 650
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
