Shifting without clutch!!??
Old Mar 8, 2005 | 01:29 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Default RE: Shifting without clutch!!??
ORIGINAL: Choppa
i kno u can slide it out and into neutral when in like third and 4th i do in my car (not alot at all) but i doubt u can do it trying to put it into gear
Word. I had a 90 lx 5.0 that you could slide it out of gear, never tried to shift into a gear.
Old Mar 8, 2005 | 02:49 AM
dc_mann8's Avatar
dc_mann8
when my clutch cable went, the whole drive home was without the clutch. what you do is put it to the floor and when at WOT jam into gear (worked for me, and thought its how its done)
Old Mar 8, 2005 | 07:05 PM
dan's Avatar
dan
WOT, id think that would destroy your tranny
Old Mar 8, 2005 | 08:14 PM
Tims 88GT's Avatar
Tims 88GT
hehe, if i had a beater i would try it, but i dont so it aint happning. it's not that hard to push the clutch in
Old Mar 8, 2005 | 08:16 PM
Tims 88GT's Avatar
Tims 88GT
also big trucks do it because they do not have sincros in the trans their is to much weight and power it would just bust the teeth off them, in your t-5 you do thats why you cant.
Old Mar 9, 2005 | 10:16 AM
horseshoeing's Avatar
horseshoeing
I did it all the time in a big rig, but not in a car. Taking it out is fine, but putting in gear is not. I had a 3 speed I was throwing away and I did it with it. In a big rig you shift about 1800rpms and put it in about 1500rpms.
1. drive you to 1800rpms
2. let off the gas and at the same time, pull it softly out of gear.
3. Let you motor rpms go down to 1500rpms and push it into the next gear up.
4. when it is in gear, gas on it.
This will not work for a car.
Old Mar 9, 2005 | 08:17 PM
thelast50ho's Avatar
thelast50ho
ive shifted with out the clutch many times in my stang. its easy you just push it tarward the gear your shifting into and wait till the rpms come down
Old Mar 9, 2005 | 08:32 PM
TheAntiRice's Avatar
TheAntiRice
You can shift up easily without the clutch, to downshift you steadily apply throttle to get the rpm's up until the shifter slips out of gear and then you shift.
Old Mar 10, 2005 | 05:17 AM
xjarhead1999's Avatar
xjarhead1999
i havent and wont try it in my mustang unless i have to. i have shifted without a clutch before in an old 77 toyota pickup. clutch went out on me and i had to get it back home. when it was time to shift i would pull it out of gear and gently push it toward the next gear.i could feel the vibration and when i knew it was the right time i shoved it into gear. no grinding, no weird noises or nothing. only problem was when i had to stop. if i could just slow down it wasnt a problem. if i had to completly stop, i would have to kill the engine, put it in first and start it while in gear while flooring it. alot of jerking but it took off. that was an advantage of not having a clutch safety switch. i drove a little over 200 miles like that. never had a tranny proble the whole time i owned the truck.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
