dispute
Old Mar 10, 2005 | 02:07 AM
kirchn33's Avatar
kirchn33
Default dispute
ok i had an arguement with a friend tonight about the gears that i will be installing soon, i am getting 410s and he says that at the track i am going to run out of gear because i have a 5speed and will have to go into 5th gear which is overdrive. if you have any knowledge or experience with 410s then please help solve this lol
Old Mar 10, 2005 | 03:32 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Default RE: dispute
From what i gather a gear will improve your quarter mile time.
Old Mar 10, 2005 | 03:34 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: dispute
youll be fine. with those mods you wont run fast enough to run out of gear. i would think you could run as fast as low 11's with that gear and not run out
Old Mar 10, 2005 | 10:58 AM
dc_mann8's Avatar
dc_mann8
Default RE: dispute
yeah its around 11s when u will run out, but by that time u need a larger slick and slows you down in the mph so you will gain some gear back
Old Mar 10, 2005 | 11:44 AM
horseshoeing's Avatar
horseshoeing
Default RE: dispute
Goto the track and tell us. I think your friend is wrong.
Old Mar 10, 2005 | 01:14 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: dispute
your gonna need alot more power than what you have now to run out of gear in 4th
Old Mar 10, 2005 | 02:14 PM
roundman's Avatar
roundman
Default RE: dispute
your friend is wrong, you will not need to worry about it unless you are running smaller than stock diameter rear tires.
Old Mar 10, 2005 | 02:34 PM
96SilverLT1's Avatar
96SilverLT1
Default RE: dispute
I would think he is wrong.. but you should look for a calculator online that will tell you for sure. I used to have a link. I'll see if I can find it.
EDIT: http://www.csgnetwork.com/gearratcalc.html
jamieNerikas66stang
Apr 11, 2008 10:23 AM
torch red
Aug 21, 2007 01:23 PM
willyd465
Aug 29, 2006 02:46 PM
