rear end swap
Old Dec 4, 2007 | 08:57 PM
Cryptostorm's Avatar
Cryptostorm
Default rear end swap
anybody know if the rear end from a 89 GT will fit into a 98 stock?
ill probably put 3.55s in it... but the stock rear end on the 98 isn't popin with me...
also, did the 89 have disk breaks all around? if not, how hard is it to use the existing disk breaks on the 98 on the 89 rear end?
thanks in advance
Old Dec 4, 2007 | 10:37 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: rear end swap
Is your '98 a sixer? If so, the brakes won't swap. Dunno about the breaks, though.
The chassis is basically the same, so the rear should be pretty much a bolt in.
Old Dec 5, 2007 | 01:29 PM
blwn93gt's Avatar
blwn93gt
ORIGINAL: Colorado_Mustang
why would you tell someone that if you dont know! I have a 93 rear in my car with brake rotors and calipersfrom a 96 v6 mustang.
it doesnt matter if your car is a v-6 or a v-8. you can use the disk brakes off the 98 and put on the 89 rear. the 89 came with drum brakes. it will be an easy bolt in swap. ford used the same brakes on the 7.5 and the 8.8 the only difference in brakes is that the cobra got larger ones. its common for us fox body guys to use parts from the 94-98 to do a five lug conversion. in 99 they stared using longer axles.
edit: dont forget you will need to put the 98 axles in the 89 housing.
Old Dec 5, 2007 | 11:26 PM
onegreedy's Avatar
onegreedy
i thought 94-98 were wider than the fox, i know for sure the 99-04 is wider than the 94-98!
Old Dec 6, 2007 | 05:49 AM
blwn93gt's Avatar
blwn93gt
the only thing that makes them wider is the axle length. the housings are the same. the 94-98 axle is 3/4" longer than the fox axle, and the 99-04 is 1 1/2" longer.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
