door hinges and pins
Old Dec 5, 2007 | 07:26 PM
eaglescout's Avatar
eaglescout
Default door hinges and pins
does anybody know or can tell me how to replace the pins and bushings on my 1993 lx? I believe its probably something I can tackle myself. Also how about the handles do they bolt in from the inside? or are they riveted? any info is appreciated
Old Dec 7, 2007 | 03:52 AM
eaglescout's Avatar
eaglescout
Default RE: door hinges and pins
Can somebody please help me here? I understand you have to grind the head off the pins somebody must have done this to there stang
Old Dec 8, 2007 | 05:58 AM
corvetteguy's Avatar
corvetteguy
I have heard that you don't want to
change the pins. People who do wind up
with a door that is too low and has to be
lifted each time the door is closed so that
it latches again.
I would look into shimming the hinge before
such a drastic step.
The door handle is riveted (2) and has to be
drilled out. Then it removes from the outside.
Make sure you replace it with a METAL latch.
You can use carridge bolts with nuts on the
inside. You may have to file the bolt to
make it fit nice.
You can use a GIANT pop rivet if you can
find such a beast.
jerrytubes
Oct 23, 2015 12:11 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
