My battery keeps dying and I don't know why...please help
Old Dec 24, 2007 | 03:15 PM
kenv's Avatar
kenv
Default RE: My battery keeps dying and I don't know why...please help
My `87 Corvette was doing that. I did not drive it for a few weeks & BAM! dead battery. I now keep it on a battery tender---- Works like a charm & the best part is, you can get a cheap one for under $10.00 from Harbor Freight
Old Sep 16, 2008 | 10:20 AM
mtb4ever's Avatar
mtb4ever
There are only a few things that can cause parasitic battery drain:
The battery itself - test it properly or have it properly tested.
The charging system - alternator output can test OK (13-15V output), but a bad diode in the alternator can cause a drain. Leave the car off and the battery connected for a while then touch the alternator. Is it warm or hot? Replace it. This was my 68's problem. I replaced the regulator too for good measure.
A short or open circuit in the system - this the nasty one and hardest to trace. If battery and alternator and known to be in proper working order, disconnect the positive battery cable and connect a volt meter to the positive battery terminal and the disconnected positive cable. Depending on your car accessories there should no drain or only be a couple of volts at most. If you know how, check the amp draw. It should be under 50 or so, but I could be wrong on that - don't remember. Check your manual for proper current draw results when the car is off. If you believe it's short, then one by one start pulling fuses to identify the circuit with the problem. Then check all the wiring for problems.
Typical items - glove box light stays on, trunk light stays on, after-market stereo incorrectly connected or stereo malfunctioning, recent body repair crimped a wire, recent replacment of electrical equipment or add-on of electrical accessories has a shorted wire somewhere.
Good luck!
Old Sep 17, 2008 | 05:34 PM
turbomustang18's Avatar
turbomustang18
mine was too, then found out bad alternator
StalkerGT
Sep 25, 2015 02:41 PM
Roush05
Sep 10, 2015 12:23 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
