Weird Noise. HELP!
Old Dec 30, 2007 | 03:50 AM
SD05GT's Avatar
SD05GT
Default Weird Noise. HELP!
OK I PUT ON MY SLP LOUDMOUTH AXELBACK 9 DAYS AGO. AFTER ABOUT 4 DAYS OF DRIVING THE CAR WITH NO PROBLEMS (LOUDMOUTHS SOUND GREAT BY THE WAY) I STARTED TO HEAR A FUNNY NOISE. NOISE IS MOSTLY PRESENT AT NIGHT AND ONLY WHEN IM TAKING OFF FROM A STOP OR BOGGING THE ENGINE IN SAY A GEAR TO HIGH. I ALSO SHOULD NOTE THAT THE NOISE IS NOT ALWAYS THERE. LIKE I SAID ITS MOSTLY AT NIGHT AND SEEMS TO COME IN WHEN THE CAR HAS BEEN DRIVEN AND FULLYWARMED UP? IT SOUNDS LIKE SOMETHING IS LOOSE. MAKING A RATTLING SOUND. The rattle is rpm specific. It comes in between 1000 - 1500 rpm's. NOTE I HAVE BEEN UNDER THE CAR 3 TIMES MAKING SURE THE EXHAUST I RECENTLY INSTALLED WAS ALL TIGHT. DOES ANYBODY HAVE ANY SUGGESTIONS? IM THINKING ABOUT TAKING IT TO THE DEALER AND HAVING THEM LOOK AT IT .
Old Dec 30, 2007 | 07:26 AM
ewgoetz's Avatar
ewgoetz
Default RE: Weird Noise. HELP!
check to see if hte exhaust is taping against somehting. A few years ago I put on a cat back exhaust and the tail pipes were close to the gas tank tapin away at it. It wasnt always there as well. I would make sure yur exhaust is at least a half inch away from anything(frame or gas tank).
Old Dec 30, 2007 | 07:49 AM
Big Top Gt's Avatar
Big Top Gt
Usually, you find the exhaust rattling against the lower control arms.
What happens is you install the exhaust with the rear hanging down. When you drop the car back onto it's wheels, you load the suspension.
My buddy's 99 GT does the same thing, but I'm too lazy to slide under it and fix it.
All you need to do is jack the car up and put jack stands under the axle tubes. Lower the car onto the jackstands, and look at the exhaust. You'll see where it's a little too close.
Simply loosen the bolts that hold the back section together, and move the pipes as necessary.
Good luck,
Alan
Old Dec 30, 2007 | 08:37 PM
SD05GT's Avatar
SD05GT
Thanks guys. I'll be sure to check it out and i'll let you know if the problem is resolved. Is there anything else that might be causing the problem?
Old Dec 31, 2007 | 12:08 PM
onesickstang01's Avatar
onesickstang01
not sure where the exhaust runs on yours but my 01 would hit on the tank and sometimes the control arms
Old Dec 31, 2007 | 05:06 PM
LBD's Avatar
LBD
Not famillir with system but, possibly; somthing came loose in the flow path causing yer vibrato.
Sometimes new stuff is just born bad...
bjdutch2005
Mar 24, 2017 03:38 AM
6bangr
Feb 15, 2016 07:40 AM
mungodrums
Sep 28, 2015 10:54 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Emblazoned
Sep 3, 2015 10:45 PM
