Any ideas?? :)
Old Jan 11, 2008 | 04:10 PM
gallwina's Avatar
gallwina
Default Any ideas?? :)
Hi there everyone...
My husband owns a 1996 Ford Mustang. He has been having some problems with the passenger side window.
It started by rolling down and only would roll up intermittently, now it won't roll up at all. My husband said that he doesn't think it is the motor because the window would probably roll down more if it could. The drivers side controls won't work it at all, and the passenger side was the only side that actually worked when this all started.
Anyone have any idea what the problem might be?
Thank you
Charmaine
Old Jan 11, 2008 | 04:45 PM
GreyStang's Avatar
GreyStang
Default RE: Any ideas?? :)
Sounds like an electrical problem somewhere.. when the window DOES work does it move smoothly? Probably the switch is corroded or something like that
Old Jan 11, 2008 | 06:27 PM
ewgoetz's Avatar
ewgoetz
I would guess it is one of the 2 switches.
Old Jan 11, 2008 | 10:49 PM
nitrous_bob's Avatar
nitrous_bob
best way to check is to "jump" the switch
bypass it by pulling off the door panel and putting juice to the motor itself , if it moves it, the switch is bad
if it does not...the motor is bad
i would bet motor though.......the switch is inside and doesn't usually corrode, the motor is in between the door and does
Old Jan 12, 2008 | 06:15 PM
ewgoetz's Avatar
ewgoetz
I Would start with the switch for the drivers door. reason is she said the passengers side still worked for a bit before both cut out. If it was the motor the would both Not work at the same time. Personaly I would change out both sides cuse if one's going bad the otherside is not to far usualy.
Thunderball
15
Nov 22, 2015 11:49 PM
Sixer4Life
Oct 12, 2015 04:26 AM
ChampInSD
Oct 2, 2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
marc954
Sep 29, 2015 11:18 AM
