convertible window
Old Mar 23, 2005 | 02:26 PM
94droptop's Avatar
94droptop
Default convertible window
My driver side rear quarter window will not go up. how much will this cost can i do this my self?
Old Mar 23, 2005 | 06:40 PM
artisan00's Avatar
artisan00
Default RE: convertible window
do you know what is causing it? would make it easier to give accurate answers
Old Mar 23, 2005 | 10:24 PM
Hudson1975's Avatar
Hudson1975
if its any consolation I just paid 86 bucks for the window motor alone. Installed myself. Just keep track of where you removed every thing from for when you put it back. Make sure its the motor first. Be warned though that you will have to drill out the rivets holding the window glass in. You might need more tools then this is worth. I'd look into having a shop do it if I were to do it again. BTW mine was the driver side front window, Yours may be less expensive.
Good Luck
Carl
Old Mar 24, 2005 | 11:51 AM
artisan00's Avatar
artisan00
well, the reason i asked, was because i also had an issue with driver side passenger window in my 03vert. it would go down, but not up. it wasnt the motor... it was the little rubber/plastic gaskety thing that you can see there when the door is open. it was messed up - i forget how i fixed it but it was just a matter of messing around with it to get it to work
Old Mar 25, 2005 | 10:10 PM
SShadowSSin's Avatar
SShadowSSin
Look here THis guy installed it himself, and he said that it was the easiest thing he ever did, and regreted ever paying anybody to do the other side. He might be the guy to ask. Good luck.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
