Break in Period
Old Mar 23, 2005 | 11:17 PM
Debris33's Avatar
Debris33
Default Break in Period
I asked my dealer about the break in period on my 05.
They said no break in period?????? huh ????? I said. He said Nope... No breakin Period. Jus keep your oil changed every 3000.
Some guy posted last night that that we should dump the oil at 500 mi & Change the tranny fluids due to the break in.
I now have 500mi What do you say?
My Dealer also put a sticker on the window as a reminder to have the oil changed at 3000
Anybody ??
Old Mar 23, 2005 | 11:34 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: Break in Period
i doubt there is a break in but i would say 500 miles would be more then enough. if you want to change the oil, go for it. wont hurt anything
Old Mar 24, 2005 | 11:36 AM
Chopper's Avatar
Chopper
Change the oil and if you want a good scare look into the drain pan after you dump it.There will be shavings and all kind of junk,expensive looking junk,in the bottom.Don't worry though,it's normal.I canged mine at 500 mi.and use Mobile 1,0-20.Next do the tranny,use the synthetic of your choice.
Old Mar 24, 2005 | 12:32 PM
Acer2428's Avatar
Acer2428
Site Mod
I like to change it at 500mi (use organic) then again at 3,000 miles and use synthetic this time. Try to vary your rpms as you drive for the first few hundred miles, no redlining it, will help your car last a lot longer.
Old Mar 24, 2005 | 03:51 PM
vfast's Avatar
vfast
I ♥ Acer
I do as follows
250 miles... install magnetic drain plugs
500 miles
1000 miles
2000 miles....all using 10w 30 reg oil
3000 miles 10 w 30 syth. oil...
Old Mar 24, 2005 | 03:56 PM
snlpa's Avatar
snlpa
ORIGINAL: vfast
I do as follows
500 miles
1000 miles
Yes I like this Idea.....vfast that sounds about right!!
jwog666
Dec 27, 2021 08:09 PM
aznpersuasion
Jul 11, 2018 06:40 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
Blk Vert
Sep 9, 2015 12:16 PM
