installed headers have problem help please!!!!!!!!!!!
Old Mar 24, 2005 | 02:43 AM
philthy89fifty's Avatar
philthy89fifty
Default installed headers have problem help please!!!!!!!!!!!
i recently installed some jba shorty headers and now at a certain point in the steering wheel it is tough to turn. i know the steering column (shaft) is rubbing . how do i fix it? it only does it when i'm turning right. can i grind a little metal off the shaft? our do i have to beat the hell out of that header?
Old Mar 24, 2005 | 09:53 AM
brando5.0's Avatar
brando5.0
Default RE: installed headers have problem help please!!!!!!!!!!!
I would beat the header. It may disrupt the flow a little bit, but I dont think you could take enough off of the steering shaft to make it clear easily, and still leave enough of the shaft to drive it safely.
Old Mar 24, 2005 | 03:04 PM
Dan04COBRA's Avatar
Dan04COBRA
New Motor mounts should fix this problem.
Old Mar 24, 2005 | 04:49 PM
roundman's Avatar
roundman
just put a small dent in the header tube that is rubbing on the steering shaft. I had the same problem with MAC equal length shorties too. you might need to drop the shaft to be able to make the dent exactly where it needs to be made but this is easy enough to do, just mark the tube with a marker where the dent needs to be before you drop the shaft out of the way.
Old Mar 24, 2005 | 06:01 PM
Dan04COBRA's Avatar
Dan04COBRA
Settled or old motor mounts will let these things happen.
I'd really hate to see you dent a tube for clearance. How bad is it rubbing?
Old Mar 24, 2005 | 06:19 PM
philthy89fifty
its barely rubbing i'd say a milimeter or less i'm with you dan i would hate to dent these headers for a milimeter . thanx for all the feedback.
djbigskrilla
Sep 20, 2022 01:04 AM
DrunknRuckus
Aug 23, 2015 10:05 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
jjwinel78
Aug 17, 2015 03:34 PM
