fluid change ???
Old Jan 17, 2008 | 10:30 PM
scotty97gt...'s Avatar
scotty97gt...
Default fluid change ???
new to this forum i just bought a 97 gt vert mint con, 32,000 k my ? is i"m going to be changing all the fluids and any help would be great. is there anywere i can go to to get this information.
thanks for any tips
[IMG]local://upfiles/88345/00999CDAEA1F459AA6FA8A59DF22E429.jpg[/IMG]
Old Jan 18, 2008 | 12:31 AM
Ecstasy's Avatar
Ecstasy
Default RE: fluid change ???
is it a standard or auto? here ill make recommendations.
Oil Filter: Motorcraft FL280S
Oil: Mobil: 10w-30
Oil Additive: Lucas Synthetic Oil Stablizer
Tranny Fluid(If Manual): Pennzoil Synchromesh
Tranny Fluid(If Auto): not sure, i believe its dex 3 merc(but check to make sure)
Run 93 octane the first few tanks(i run 93 always) and once a month i run lucas fuel injector cleaner through it.
anything else just ask.
Old Jan 18, 2008 | 08:37 AM
stealthyone's Avatar
stealthyone
personally I would not run Lucas in my car... from experiance I have seen it cause the oil to foam up.
Old Jan 18, 2008 | 03:24 PM
scotty97gt...
Sorry i gess i should have said it"s a 5 speed and i"m looking to change the rad,tranny, i just got the car and i didn"t ask when the last time they were done so i thought i would do them
thanks 4 any reply
[IMG]local://upfiles/88345/44DCF0F6898A40DB9CCD9DB7B57F8BF5.jpg[/IMG]
[IMG]local://upfiles/88345/276A382D7F0044EC9D2E7A9AE981BDDD.jpg[/IMG]
[IMG]local://upfiles/88345/CE2C5C790F4244729854AFC35A44D697.jpg[/IMG]
Old Jan 18, 2008 | 04:24 PM
99_GT's Avatar
99_GT
Nice ride,i like the wheels. I'd do the trany, cooling sys, rearend, and i wouldusewhat the manufacturerecomends.
Old Jan 18, 2008 | 04:31 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Ecstasy
Oil: Mobil: 10w-30
On a car with that low of miles during the winter time, 5w-20 or 5w-30 is recommended
You realize that product (Synchromesh) is GM and Chyrsler spec right?
Ford manual tranny fluid is also Dex 3/Merc
And unless you have a 93 octane tune, don't bother...money down the drain. Higher octane does nothing for a stang (or any car for that mater) that is tuned for 87 octane.
Fuel injector cleaner is a matter of preference as is oil additive (Although oil that meets or exceeds OEM spec is plenty, again money down the drain but it's still a preference).
Old Jan 18, 2008 | 09:01 PM
scotty97gt...
Thanks 4 the information
Old Jan 18, 2008 | 11:17 PM
blackstalion232's Avatar
blackstalion232
ORIGINAL: Ecstasy
Oil: Mobil: 10w-30
the oil filter is a motorcraft fl820 if its a v8 or if its a v6 then its a motorfcraft fl400 i change oil for a living trust me also would do a tranny drain and fill along with rear differential and probally a injector flush and change the air and fuel filter along with flushing the radiator if you wanted to you could also do a power steering and brake flush
Old Jan 20, 2008 | 03:08 PM
Jfsram's Avatar
Jfsram
Don't forget the differential and trac lock additive. Brake fluid, an often neglected fluid. The radiator should be mixed with distilled water.
stangin1996gt
Sep 21, 2015 11:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
