key problems
Old Jan 19, 2008 | 11:55 AM
ricojsuave's Avatar
ricojsuave
Default key problems
My key will no longer open the trunk on my 97 GT. I have a trunk release button in the glove box so I can still get it opened, but what would be a fix for this? Any ideas?
Old Jan 19, 2008 | 04:18 PM
ewgoetz's Avatar
ewgoetz
Default RE: key problems
What do you mean it won't open it anymore? has the key cy,inder fallen out? or does it now turn in the cylinder?
You can either buy one cylinder just to replace that one, or buy a whole set to replace tham all. Some dealers can set they new cylinders to use your old Key also. You can also go to a lock smith and see if they can replace it and match the cylinder to the old key.
Old Jan 19, 2008 | 05:47 PM
raginglunatic77's Avatar
raginglunatic77
There may be no need to replace the lock cylinder. First take a can of spray silicone lubricant and spray the key on the metal, cut portion (ideally use an original key not a copy). Then put the key in the lock and take it out. Do this several times and then try to turn the lock and keep lubing the lock. The locks on my 96GT stopped working and I just lubed them and they all work flawlessly now.
Meystang
Sep 25, 2015 04:05 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
5.0 kevo
Sep 3, 2015 06:24 PM
