vert VS. coupe
Old Mar 27, 2005 | 01:58 PM
blank's Avatar
blank
Default vert VS. coupe
i know a vert has a weaker chassis than a coupe. how much power can a vert take compared to a coupe
Old Mar 27, 2005 | 03:38 PM
dan's Avatar
dan
Default RE: vert VS. coupe
what do you mean by how much power can it take. Also, the verts are a little heavier
Old Mar 27, 2005 | 03:54 PM
Ezrider's Avatar
Ezrider
well the vert and the coupe have the same drivtrain and you can mod them the same, but like already stated the vert is heavyer and a weaker chassis
Old Mar 27, 2005 | 06:23 PM
blank's Avatar
blank
how much hp and torque could a vert handle without breaking it
wieght is no problem
Old Mar 27, 2005 | 07:44 PM
blueangelfightr's Avatar
blueangelfightr
The same amount as a coupe. The only thing your limited by is all of your internals and stuff.
Old Mar 27, 2005 | 09:03 PM
Ezrider's Avatar
Ezrider
like i said the drivetrain is the same you can put out just as much hp as the coupe, its not like your going to break the car it two
Old Mar 28, 2005 | 01:47 AM
Aixtreme89's Avatar
Aixtreme89
I think hes refering to breaking the chassis. It wouldnt really be any weaker than the coupe. The added weight is because of the greater chassis stiffening that ford did. But with either car should have sub frames, or a frame kit installed to prevent the chassis from flexing and screwing with the geometry of the suspension and alignment.
Old Mar 28, 2005 | 03:16 AM
Acer2428's Avatar
Acer2428
Site Mod
I may be wrong, but I thought they were heavier b/c of the motor/other things involved w/ the top?
Old Mar 28, 2005 | 04:19 AM
dc_mann8's Avatar
dc_mann8
as did i...
Old Mar 28, 2005 | 11:03 AM
xjarhead1999's Avatar
xjarhead1999
when i was putting my subrames on another mustang came up to have some exhaust work(was at a muffler shop a friend runs) anyway i went to help and i noticed that his didnt have a couple small braces that mine did. i dont think its alot though. i believe that most of the weight is because of the motor and other things involved with the top.
robcy
Suspension
Oct 27, 2015 11:14 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
JT76
Sep 20, 2015 11:32 AM
