rear end fluid change question!!! help.
im out in my garage changing my fluids in the rear end and i got all of it out and got the cover back on...but when i went to get the plug out it wouldnt budge and it got kinda messed up in the process.
question is, can i put the fluid in ziplock bags and stick them in there and seal the cover then just drive? it will burst the bags open and disinigrate the bags?
i herd of this being done before...just wondering if it is worth it..
jesse.
jesse.
you can also drill a hole in the cover above the oil level and
put it in that way too, you will just need to find a rubber plug to slip in the hole, some of the older mopars from the factory had rubber plugs , i have actually done that to all mine as filling it from the front is a pain in the a--
u better not put plastic bags in your rear end!!!!!!!!!!!!!!!!!!!!!
first of all try spraying it with some penetrating oil.. letting it sit for a little bit and try getting it out... if it gets stuck or strips and your screwed...
IF you have to...drill a hole in top of cover and pour in fluid..SEAL hole... get it to a shop.. and get it fixed right...and get a new cover...
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
Greyshot
Aug 15, 2015 03:32 AM
92 5.0stang
Aug 13, 2015 06:46 AM
