5.0 into a pinto...
Old Feb 2, 2008 | 09:11 PM
The Stock one's Avatar
The Stock one
Default 5.0 into a pinto...
Ok I know its not a mustang, but it was my first car its a 77 pinto wagon. My question is what all would be required to drop a 302 in. any major modding or cutting or would it be a fairly easy thing to do. I figured it could be a decent sleeper something to play with on the weekends. and you don't see very many pintos fixed up thats not on a drag stripHeres a Pic incase you wanna see what it looks like. Thanks for any help
Old Feb 2, 2008 | 09:38 PM
ewgoetz's Avatar
ewgoetz
Default RE: 5.0 into a pinto...
I remember seeing a 427 droped into a pinto several years ago in a mag. Think it was in Fast fords and mustangs. It bearly fit in it and it was mean lol. Think it was in the Mid 90's I saw it in.
Old Feb 3, 2008 | 05:42 AM
Gary H's Avatar
Gary H
It's a bolt in, ford version of the V-8 vega. I friend runs one in Denver.
http://www.geocities.com/g_wellwood/...e/v8pinto.html
Old Feb 3, 2008 | 06:17 AM
uedlose's Avatar
uedlose
man thats Cool I had two v8 pintos when I was younger like 18-21 one had a hooker install kit the other I bought done. I dont remember much on what it took to put them in I paid a guy to do one for me. But there was not much cutting at all. remember the Mustang ll was just a warmed over Pinto.
Old Feb 3, 2008 | 06:50 AM
purpletman's Avatar
purpletman
Lots of these around when I was a kid, V-8 in Pintos pretty much a breeze, just remember the
mutang II's of 74-78 were built on the same platform so a lot of the things you need will interchange from them, and I still see some of them setting around. If memory serves me correctly you'll need a set of motor frame mounts from a mustang II (e-bay man!) and a radiator, and a transmission crossmember and mount. I think your going to find most of these
things really easy to get. I did one these when I was a kid and did it the cheap way and made all the parts but the way I described earlier is pretty much a bolt-in. Good Luck!
Old Feb 3, 2008 | 07:30 AM
The Stock one
ok cool, thanks, i was wanting to replace the entire driveline, my plan was to buy a wrecked fox body and take every thing from it.
Old Feb 3, 2008 | 05:18 PM
purpletman's Avatar
purpletman
If you can buy a fox body really cheap that will be o.k. but if not I'd just look for a complete
early model junker like an old '60s model (68-69-70) good compression, carburated, easy to work on. The only thing of use to you out of fox body will be the engine and trans., the rear is of no use because your car is a leaf spring car not coil and trailing arm. If you want a good rear this is tough to find maybe but a '55-'56 fairlane rear is about the right length for what your doing it might be a little wide I think they are 561/2" drum to drum. my fist donor car was a '66 Galaxie something like that would give youmost likely a 289 and a C-4, probably a cheap solid start, stay after it man you'll have alot of fun. Good Luck!
Old Feb 3, 2008 | 07:17 PM
95greengt's Avatar
95greengt
ive been wanting to do the same thing just to do something different
Old Feb 3, 2008 | 09:42 PM
The Stock one
yeah i've been wanting to for a long time, just that life keeps comming up..
Old Feb 5, 2008 | 04:47 PM
The Stock one
so i'm gonna have to keep the leaf spring set up, to put the other set up would be a **** ton of fab work.
Granatelli Sales
Mar 25, 2016 08:01 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
