check engine light goes on and off
Old Mar 31, 2005 | 11:07 AM
chefbill's Avatar
chefbill
Default check engine light goes on and off
the check engine light will stay on for a while and then go off for a while...on,off,on,off......took it to the a dealer and they got no codes when they check it out....anyone experience this?
Old Mar 31, 2005 | 01:35 PM
86HOGT's Avatar
86HOGT
Default RE: check engine light goes on and off
I wonder if they didn't any KOEO or KOER tests to verify your problem. If you can, get a scanner and see what you can get for codes and such and go from there.
Old Mar 31, 2005 | 07:12 PM
Demon_Mustang's Avatar
Demon_Mustang
idle = off
rev = on?
Do you have aftermarket exhausts? It's basically the car's environmental system telling the car that it is getting abnormally high pollutant readings and it's recycling the exhausts into your engine to be burnt a second time. Not a good thing, I think you should use some kind of EGR simulator to eliminate that...
Old Mar 31, 2005 | 07:41 PM
stanglx2002's Avatar
stanglx2002
i used a block off plate
Old Apr 1, 2005 | 01:00 PM
chefbill's Avatar
chefbill
comes on and goes off at random....
Old Apr 1, 2005 | 01:22 PM
FiveOhNo's Avatar
FiveOhNo
make sure all connections are tight...my egr connection was loose (the clip holding it broke), and it would randomly turn on and off.
Old Apr 1, 2005 | 03:42 PM
91hatchgt's Avatar
91hatchgt
It is most likely the EGR... My bro had the same problem with his.. take the EGR valve off the spacer, and spray some carb cleaner into it, and massage the prong in and out to make sure it is not getting stuck shut/open... This worked for us.
Old Apr 1, 2005 | 05:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 91hatchgt
He has it blocked off....
The fact it's flashing on you could mean the O2 sensor is getting some funky readings. Take the O2 sensor(s) out and clean off any carbon deposits on them. Use a brass brush, no carb cleaner, and compressed air if you have it. Do you smell gas coming out of the exhaust? Could be lean or rich mixture that's trippin' the light. If you smell gas, it's definitely a rich mixture.
Old Apr 4, 2005 | 01:01 AM
Gaspi101's Avatar
Gaspi101
the computer turns on the check engine light when it reads an error, and then turns it off if the error does not occur for several "trips." The softcode should still be stored in your computer, but if the car is not manifesting any problems, and the light goes on and off, it is more than likely a simple and innocuous misreading-O2 sensor or another sensor. If I were you, I wouldn't worry about it in the slightest.
Old Apr 4, 2005 | 01:10 AM
dc_mann8's Avatar
dc_mann8
mine does the exact same thing.. i just always assumed its my exhaust? headers o/r h and flows.. ?
