quick question
Old Feb 21, 2008 | 10:30 PM
dubsat510's Avatar
dubsat510
Default quick question
am i wrong or does getting aftermarket exuast better your gas millage?
Old Feb 21, 2008 | 10:33 PM
dirt_mcgert's Avatar
dirt_mcgert
Default RE: quick question
it might alittle but not really enough to tell a difference
Old Feb 22, 2008 | 06:26 AM
GreyStang's Avatar
GreyStang
Put on too large ofdiameter exhaust pipes & your fuel economy might even get worse.. Some think "the bigger the better" and put 3" dual exhaust on their mostlystock car, which will reduce backpressure too much.
Old Feb 22, 2008 | 06:53 AM
Chopper's Avatar
Chopper
I have a full Bassani exhaust and it made no difference at all.
The biggest thingI did that helped mileage was to bump the timing.That won't help any if you don't advance the timing from idle.
Old Feb 22, 2008 | 02:27 PM
tylerl90's Avatar
tylerl90
Longtubes, O/R midpipe, and a good catback usually helps it out. But it's not very noticable.
Old Feb 23, 2008 | 10:27 AM
onesickstang01's Avatar
onesickstang01
greystang is correct, i had the same problem, i had to throw in a h-pipe to make up for a little compression loss. i felt the difference in power but the gas mileage slipped away a little. until i put the h-pipe in it ran like **** too
Old Feb 23, 2008 | 02:05 PM
tbirdscwd's Avatar
tbirdscwd
Not enough to really notice, maybe a few miles per tank. Most people tend to be a little happier on the throttle after an exhaust install and cause a decrease in mileage.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
