another newb with another question.
Old Feb 25, 2008 | 09:01 AM
zippo2341's Avatar
zippo2341
Default another newb with another question.
so i replaced my rotors and pads the last weekend and noticed i had a cracked coil spring, yesterday me and my girls cousin, owner of solowcustoms, replaced the coil spring, and it took a little more then finess to get that b*tch in, However no when i go down the road im getting a scraping noise coming from the drivers side brakes. as soon as i hit the brake pedal it goes away. i cant figure it out i just did the brakes last weekend, and we never took the caliper, rotor, or brake pads off? any ideas on what to look for?
Old Feb 25, 2008 | 09:49 AM
MU71L4710N's Avatar
MU71L4710N
Default RE: another newb with another question.
make sure the pads are still good, make sure the metal clip that holds the calipers on isnt scraping something.
Old Feb 25, 2008 | 10:41 AM
dmh@bones's Avatar
dmh@bones
Make sure that there is nothing between the calipers. The metal clips may be rubbing as well. DEf check to see if the brake pads are in good condition.
Old Feb 25, 2008 | 12:02 PM
zippo2341's Avatar
zippo2341
thanks im gonna take the wheel off and check it out tonight, i just cant think of anything right now cause the brakes are new, and when we did the spring, we never took off the caliper rotor etc. thanks for the advice those guys
Old Feb 25, 2008 | 12:24 PM
zippo2341's Avatar
zippo2341
Default RE: another newb with another question update.
also the noise isn't constant its in rythym with the wheel as it turns, like it only rubs when the wheel is in a certain part of its rotation.
Old Feb 25, 2008 | 05:14 PM
SCCAGT's Avatar
SCCAGT
EASY FIX. The backing plate probably got bent while you were under there messing around. Check and see if its seems like its right on the rotor. If it is then just pry it away with a screwdriver a little bit. Then drive again to see if noise is gone.
tmdm
May 2, 2021 02:49 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
mdj89
Aug 31, 2015 07:27 AM
toastintx64
Aug 29, 2015 05:12 PM
MusBBad95
Aug 17, 2015 09:39 PM
