No spark
Old Mar 1, 2008 | 04:53 PM
bjt2240's Avatar
bjt2240
Default No spark
Ok, I'm @ a lose, I have a 86 mustang lx, 5.0. I have replaced the battery, plugs, wires, ignition mod, coil, distributer cap, rotor! Still can see any spark at the plugs. Can sombody keep me from pullin the rest of my hair out?
Old Mar 1, 2008 | 04:58 PM
BLK89GT's Avatar
BLK89GT
Default RE: No spark
how are you testing to see if there is spark
Old Mar 1, 2008 | 05:04 PM
bjt2240's Avatar
bjt2240
Removed the # 1 plug wire and attached a ignition tester to the wire then clamped the tester to a nearby bracket. Also test #3 #5 and #8.
Old Mar 1, 2008 | 06:15 PM
solo_ryder's Avatar
solo_ryder
ground out the plug against something your can't just pull it out
Old Mar 1, 2008 | 06:43 PM
P.S.I.cho's Avatar
P.S.I.cho
ORIGINAL: solo_ryder
hes using a spark tester so hes doing it 100% right, actually more correct then what most people do.
check the coil, if the coil is getting spark, then check the coil pickup inside the distributor, (not sure but i think its called the stator), if the stator is good then its probly the TFI module. im not familiar with the 86 but it should have a TFI.
Old Mar 2, 2008 | 07:53 AM
bjt2240's Avatar
bjt2240
I checked the coil the same way, was that correct? I'm not real sure what the TFI is or the coil pickup. Sorry for all the questions.As you can probably tell I'm not much ofa mechanic.
Old Mar 2, 2008 | 04:31 PM
P.S.I.cho's Avatar
P.S.I.cho
ya if your getting spark after the coil, the little module on the side of the distributor is the TFI, and if you open up the distributor cap take out your rotor under neath the rotor should be the coil pick-up, and before you buy a NEW tfi have it tested at a local parts store to save some money
Old Mar 2, 2008 | 05:39 PM
bjt2240's Avatar
bjt2240
Thanks man. Idid a little diging andif I understand correctly, the pick is a trigger for the coil, it tells it when to send juice. Since I don't have spark comeing from the coil I'm under the impresion the pick up is at fault.
Now with all that done and still no spark, should I go buy a new destributor, or try to change out the pick up?
Dathan
Oct 5, 2015 05:52 AM
dalehunter
Sep 25, 2015 10:51 AM
lmurf60
Sep 24, 2015 10:07 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Emblazoned
Sep 3, 2015 10:45 PM
