Transmission problems
Old Mar 8, 2008 | 06:32 PM
uhohthe50's Avatar
uhohthe50
Default Transmission problems
I just installed a new clutch in my 88 gt mustang. After i got everything back put together and adjusted the clutch to the proper spot, i'm having a difficult time engaging the tranny in 2nd, 4th, and reverse. Is there any alingment that i needed to do to the transmission to prevent this or what can i do? Also there is a humming noise, possibly coming from the throwout bearing but it only makes the noise when the car is in neutral, any ideas what this is and how to fix it? I installed a brand new clutch, pressure plate, throwout bearing, retaining bearing, and clutch cable w/ firewall adjuster. Thanks!
Old Mar 9, 2008 | 11:25 AM
5.0 85 GT's Avatar
5.0 85 GT
Default RE: Transmission problems
you need to adjust your clutch cable again, and the tb i think you have to pull the tranny again to do it..
Old Mar 9, 2008 | 11:44 AM
08 Bullitt 2310's Avatar
08 Bullitt 2310
I think you have a shifter issue.Think about it,All of the gears you are having trouble with are engaged when you pull the shifter towards you. 135
24R See what I mean?
Old Mar 10, 2008 | 10:01 AM
uhohthe50's Avatar
uhohthe50
How can I delete this thread? My roommate accidently posted under my name since I was logged in.
Old Mar 10, 2008 | 10:15 AM
FixFalcon's Avatar
FixFalcon
LOL
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
