MY NUTS FELL OFF
Old Mar 17, 2008 | 08:30 PM
MustangMike2001's Avatar
MustangMike2001
Default MY NUTS FELL OFF
Lug nuts that is. Ever since I got my Saleens on I've had problems with them coming loose on my left rear tire and now two of them actually fell off of the front right tire. I used the original nuts which I have never had a problem with and also some locking nuts I bought. Even the new lockers are falling off. What could be the problem?
Old Mar 17, 2008 | 10:33 PM
ryan1994mustang's Avatar
ryan1994mustang
Default RE: MY NUTS FELL OFF
how many pounds do you torque them to? should be somewhere around 90 pounds...
Old Mar 18, 2008 | 10:45 AM
LilRoush's Avatar
LilRoush
Are you tightening them while the wheel is in the air, then torquing them down while it's on the ground?
Old Mar 18, 2008 | 01:29 PM
MustangMike2001
No I have been just doing it with the wheel lifted. That's how I have always done it and never had a problem till now.
Old Mar 18, 2008 | 02:23 PM
1367mustang's Avatar
1367mustang
Get a torque wrench and set to specs and redo after a few days. A MUST!!!
Adjust with car on the ground.
Regards
Brian
Old Mar 18, 2008 | 07:06 PM
ericdk5.0's Avatar
ericdk5.0
You are not getting enough torque with the tire in the air, do that first than put the tire on the ground and torque in the proper sequence. Don't just go around in a circle, go acrossed from each other in a star pattern. I torque mine to 90 foot pounds.
Old Mar 20, 2008 | 11:29 PM
MustangMike2001
So I did the whole tighten with the wheel lifted and torqued to "90" with the wheel down and the damn wheels almost fell off before I got one mile down the road.. There's no way 90 ft lbs is going to hold the wheel on.
Old Mar 22, 2008 | 01:50 AM
onegreedy's Avatar
onegreedy
something is not right, what lugnuts are you using
Old Mar 23, 2008 | 10:52 PM
LilRoush's Avatar
LilRoush
Good question.... are you using the right threaded nuts for your studs?
Old Mar 23, 2008 | 11:09 PM
MustangMan628's Avatar
MustangMan628
Lug nuts also have tapered seats on them. The part that meets the wheel usually has a certain degree of taper to it. Make sure you are using the right ones for your car. Even if the stud thread is right, the taper will cause a wheel to rattle off.
lincolnshibuya
Dec 8, 2020 01:49 PM
RCS02v6
Sep 29, 2015 01:46 PM
orangeboom
Sep 23, 2015 09:43 AM
maestro1024
Sep 21, 2015 02:40 PM
