Emergency Flywheel Help Needed!!!!!!
Old Mar 20, 2008 | 10:37 PM
TheDrivenMan's Avatar
TheDrivenMan
Default Emergency Flywheel Help Needed!!!!!!
I have just run across my first 160 tooth flywheel in a 1965 Mustang with a 289. The old flywheel is junk and there does not seem to be anyone making a replacement.
Does anyone know who makes a replacement?
I have read that the 157t/28oz is interchangable with the old 160t, but I don't want to buy another problem. Can I swap in the 157t. Will I need a new starter if I do?
Some expert advice would be appreciated! Car is holding up the rack and tempers are flaring.
Thanks!
Old Mar 20, 2008 | 11:02 PM
67mustang302's Avatar
67mustang302
Default RE: Emergency Flywheel Help Needed!!!!!!
Try posting in the classic section, someone there may know more. I wasn't even aware they use 160t flywheels on 289s, I thought it was either 157 or 164.
Old Mar 20, 2008 | 11:08 PM
TheDrivenMan
The 164t was much more common. Seems the 160t was only used in the very early 60's. I do business with a bunch of flywheel companies and none of them even list the part.
I will try putting the post in Classics as you suggest. Thanks.
djbigskrilla
Sep 20, 2022 01:04 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
MusicCity615
Sep 27, 2015 12:53 AM
defarmer
Aug 13, 2015 06:40 AM
ponyride00
Aug 12, 2015 01:57 PM
