oil pan remove ? help fast
Old Apr 14, 2005 | 11:29 PM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default oil pan remove ? help fast
well my brand new motor lost oil pressure..i shut the motor down fast...so i used my oil prime tool and i have 0 psi of pressure...so im thinking the oil pump broke for what ever reason...anyway i have new pump ready to go..now can i remove the oil pan while the motor is in the car or does it have to be pulled out?
Old Apr 14, 2005 | 11:32 PM
dc_mann8's Avatar
dc_mann8
Default RE: oil pan remove ? help fast
you have to lift it up a few inches
Old Apr 14, 2005 | 11:34 PM
5.0mustang5speed
I ♥ Acer
ok..so all i have to do is take motor mounts loose and use a picker to rise it up..please do not tease me...
Old Apr 14, 2005 | 11:41 PM
5.0mustang5speed
I ♥ Acer
is it better to just take the motor out...
Old Apr 14, 2005 | 11:45 PM
dc_mann8's Avatar
dc_mann8
completely unbolt the engine and lift it up a fair bit.. i wouldnt pull it all the way out
Old Apr 15, 2005 | 12:01 AM
5.0mustang5speed
I ♥ Acer
thanks..i will keep you posted on how it turns out....this really makes me sick..it onlys had about 1 hr running time on it..and bam no pressure...but it was bumbing hard before it went south...sounded killer....thanks
Old Apr 15, 2005 | 04:29 AM
roundman's Avatar
roundman
loosen the trans mount so you don't crack it when you pick up on the engine and make sure you don't break the ground straps on the back of the engine attached to the firewall of the car. disconnect them first to be safe. also watch the vacuum hoses too so you don't stretch or break them either.
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
wawagner82
Sep 13, 2015 09:02 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
kevsgt
Sep 9, 2015 06:20 AM
