weird idle
Old Apr 10, 2008 | 06:32 PM
FoxbodyMech's Avatar
FoxbodyMech
Default weird idle
So... I have an 85 5.0 AOD transmission, and recently she has gotten a little pissy i guess you could say. She often starts up at around 1000RPM when she used to idle at around 500-750RPM when the engine was cold, and now, when i drive her for between 5-20 minutes, when i put her in park or neutral, she idles between 2000 and 2250RPM. I have a suspicion that her o2 sensor is to blame, but i am not sure. I know she needs an in-depth tune-up because i have had her for almost a year now and have no clue how old her spark plugs, cap, and rotor are. Any ideas as to what could be causing my weird idle?
Old Apr 10, 2008 | 11:07 PM
Jarret's Avatar
Jarret
Default RE: weird idle
Don't know if this will help at all but i start mine up and its usually at about 1000 rpm's but when i idle it hits 500-750 occassionally and seems like its going to stall a little bit... I took it in to get it checked out the guy said it was the o2 sensor.. but uh like i said not sure if that'll help cuz yours is idle'ing really high instead lol
Old Apr 12, 2008 | 01:03 AM
TripleHmotosports's Avatar
TripleHmotosports
Is the engine Carb,CFI or EFI?
Old Apr 12, 2008 | 04:20 PM
FoxbodyMech
throttle body injected so kinda carb, kinda EFI lol
Old Apr 12, 2008 | 08:05 PM
TripleHmotosports
There is a choke pulloff diaphram that is probably blown. It is located on the left rear of the TB, you have to remove 2 screws that hold the housing on. The diaphram is inside. It also has a vacuum line running to it. The diaphram unscrews from the choke rod, mark the threads so it goes back on in the same spot. Probably a Dealer or Motorcraft item. Check to make sure the choke cap is working properly and voltage going to it also.
Old Apr 17, 2008 | 03:33 PM
FoxbodyMech
Yeah, i'm not too sure. I think my o2 sensor REALLY needs to be replaced. Oh well, she's getting a nice cleaning up and replacement of parts soon, so i'm just gonna go through and test everything and make sure she's up to par.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
mungodrums
Sep 28, 2015 10:54 PM
MacSerio
Sep 27, 2015 01:05 PM
