tko 600 slower than t-5
Old Apr 12, 2008 | 06:07 PM
fiveohoss's Avatar
fiveohoss
Default tko 600 slower than t-5
I destroyed my t-5 tranni and replaced it with a tko600. will my car actually run a bit slower with the tko because of the larger, heavier internals or shouldn't there really be a difference???
Old Apr 12, 2008 | 10:10 PM
67mustang302's Avatar
67mustang302
Default RE: tko 600 slower than t-5
Have you actually run it at a track before and after, with the exact same staging, 60', track and weather conditions?
Old Apr 13, 2008 | 08:54 PM
1991LX5.0's Avatar
1991LX5.0
noyou wont notice adifference, actually it might be a little quicker depending on what gear ratios you got in the trans
Old Apr 14, 2008 | 09:54 AM
fiveohoss's Avatar
fiveohoss
i never ran it at the track, here are the gear ratios if it helps:
Factory T-5 gears for my 95 GT 1st-3.35
2nd-1.99
3rd-1.33
4th-1.00
5th-.68
TKO 600 gears1st-2.87
2nd-1.89
3rd-1.28
4th-1.00
5th-.64
Old Apr 14, 2008 | 11:20 AM
golden_eye's Avatar
golden_eye
There's your answer right there. The TKO 600 has wider spaced gear ratios (or "taller" gears) overall so just swapping the trans without modifying the car will make asomewhat of a difference. Whether you are actually slower or not depends on where your powerband is and your rear end, etc... If your car is mostly stock I would venture to guess that it may be slightly slower but I can't say for sure or byhow much.
Old Apr 14, 2008 | 02:22 PM
67mustang302
That TKO 600 is designed to work better with more gear in the diff.
poke68
Dec 16, 2025 03:36 PM
Bokeo
Oct 10, 2015 08:28 PM
ChampInSD
Oct 2, 2015 04:55 AM
musnicki
Sep 23, 2015 07:11 AM
