HP? guesses thoughts.
Old Apr 13, 2008 | 10:06 AM
guch1971's Avatar
guch1971
Default HP? guesses thoughts.
Can anyone make a guesstimate of my hp? I know this is really impossible to measure without a dyno. The reason I am asking is because I am trying to match my injectors to my HP and future mods.. Here is the state of my Mods.
I know some are not HP parts, I just have them listed in annother signature..
Thanks for any responses,
Guch
Pro M 77 MAF, 65 MM TB , Vortech V2 SQ , B303 Cam. Ford Motorsport ceramic Shorty Headers, 2 1/2 MAC tubes into 2 chamber Flo Masters. Stock 19 LB injectors. Vortech BTM , Vortech FMU, Vortech pusher pump.BBK adjustable Fule pressure regulator set at 60LBs , Autolite 24 1 heat range colder plugs 160 thermostat. Timing set at 8 degrees. Auto specialties underdrive pulleys, MSD TFI coil ,9 MM wire set, 3.27 gears. JBA subframe connectors, BBK Racing springs 1 1/2 inch drop, Koni Sport shocks , Nitto Drag radials 275/45/17 , Hurst short throw shifter. Royal Purple fluids, Redline water wetter.
Old Apr 13, 2008 | 08:50 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: HP? guesses thoughts.
need to know how much boost and why is your fuel pressure set at 60 lbs???
Old Apr 13, 2008 | 09:41 PM
guch1971's Avatar
guch1971
I am running such high pressure to attempt to compensate for only running the 19 pound injectors. ( until i can figure out which ones I should go to ). Boost I should be anywhere from 8-10 with the V2 Sq, but the gauge I just installed is hard to read.. looks like 6- 7 getting some belt slippage.
Old Apr 14, 2008 | 12:00 AM
MikeIt69's Avatar
MikeIt69
1,000,000 horse power!
Old Apr 14, 2008 | 03:29 PM
guch1971's Avatar
guch1971
Iam not sure what injector size is good for that amount of horsepower, but whatever injectoryou are running in your car should more thancover mymods.
Thanks for the help!
Old Apr 14, 2008 | 04:15 PM
03GTVert's Avatar
03GTVert
I doubt anyone's going to be able to give you a good estimate of HP with your mods, but even with only 8-10 psi from the vortech I bet your'e WAY out of range with only 19lb injectors.
30lb injectors would probably be fine, but you might as well put 42's on there and call it a day. Then you're good to well over 400RWHP.
Old Apr 14, 2008 | 06:29 PM
guch1971's Avatar
guch1971
Vert, thanks for the response. Actually the 19lbs injectors were doing the job beleive it or not...... ( plugs were pulled and all looked very good) . But I am going to be moving up to the 42's since I justfound thatI haveblow-by on aheadgasket not an actual blown headgasket which causes a overheating condition which made me think i was lean.SinceIwill be pulling the heads and intake I might as well upgrade to the TFS twisted heads, and track heat intake.. ( althoughI was going to do this down the road IREALLY could have waited ) ...
lincolnshibuya
Dec 8, 2015 04:37 PM
Oct 7, 2015 07:02 PM
BeatnikFink
Oct 1, 2015 08:00 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
