Yet Another Disappointment
Old Apr 18, 2005 | 09:28 PM
grabbem88's Avatar
grabbem88
Default RE: Yet Another Disappointment
why didn't you ever mention that to me? 86hogt?[:@]
Old Apr 18, 2005 | 10:06 PM
vfast's Avatar
vfast
I ♥ Acer
what size injectors are you using?......pull the v/c and check the rocker arms..also check for a hose off for vacuum leak
Old Apr 19, 2005 | 12:43 AM
Dan89lx's Avatar
Dan89lx
my timing was @ 15 degrees at idle, i have #24's and the fuel pressure was at like 43-45. if you think that fuel pressure is high, it did the same thing at 40psi. what the hell does that little chip that you pull out when you set the timing do. it doesnt seem to make any diffrence on my car
Old Apr 19, 2005 | 12:45 AM
grabbem88's Avatar
grabbem88
that sounds about right dan...try that a9p yet??
Old Apr 19, 2005 | 01:11 AM
Dan89lx's Avatar
Dan89lx
not yet but i will get it in this weekend, is the a9p any better as far as fuel and timing curves. please tell me in detail how to set the distributor and timing cause i am gonna pull mine and change it, then set the timing with a light. i am clueless on timing. should i leave the chip in/out while timing the car. ???????
Old Apr 19, 2005 | 02:22 AM
Quik's Avatar
Quik
your heads could be to much for your setup. ppl love to buy **** they dont need. i have said many times you can got fast with e7s or gtps in stock form. to large of valves on a 302 will cause you to run less
Old Apr 19, 2005 | 02:59 AM
Dan89lx's Avatar
Dan89lx
it runs good when it runs right, it has some kind of fuel injection or ignition problem that causes it to run like hell one minute and be sick the next. i have never seen anything like it. i have box stock edel. performer heads with an Ecam, gt40 intake, #24's, 65mm tb, 75mm maf,msd, longtubes, offroad h and flows, and more but cant remember right now. i did my research and i dont think i have anything mismatched
Old Apr 19, 2005 | 03:14 AM
91LXstanger's Avatar
91LXstanger
ORIGINAL: StangTangGT
Damn dan your still havein problems with the stang huh? that blows well best of luck to ya, oh hey whats up Joe?
where u talking to me?. My name is Joe too if u where talking to someone else.lol.
Old Apr 19, 2005 | 03:24 AM
StangTangGT's Avatar
StangTangGT
oh whats up dude? no 91 hatch's name is joe to. whatever its all good. lol
Old Apr 19, 2005 | 08:46 AM
5.0carlo's Avatar
5.0carlo
Hey Dan,
That lil chip your referring to that you take out when setting your timing. Thats what locks the timing in place. From what I hear if you dont put that back it the timing could change on you. It prob wouldnt make a difference right away but Im sure given enough time it will cause something to go wrong.
carlo
