Yet Another Disappointment
Old Apr 18, 2005 | 03:58 PM
Dan89lx's Avatar
Dan89lx
Default Yet Another Disappointment
I went to the track Friday to run the car and it disappointed me worse than it ever has. I put on my ET Streets and done a hellacious burnout and pulled up to the line. I revved it to like 3500 rpms and dumped the clutch and the car ran sick as hell. it bogged all the way up the track- not bogging from the launch but from only having about 1/4 of the power it normally does. I changed my coil and ECT saturday but it made no diffrence, I got a distributor from a friend so I guess I will try that. The car was twice as fast before I put those damn heads on cause it aint been right since.
Old Apr 18, 2005 | 04:17 PM
95_302_StangMan's Avatar
95_302_StangMan
Default RE: Yet Another Disappointment
what "damn heads" did you put on.
Old Apr 18, 2005 | 04:42 PM
91hatchgt's Avatar
91hatchgt
He has the Edelbrock Heads.. Weird how it is not performing right though.. Should have got the AFR's! LOL.. (that's just a joke..)
Old Apr 18, 2005 | 04:44 PM
91LXstanger's Avatar
91LXstanger
did u examine the heads really good?. Sometimes a rocker could be too tight, or the exh. and int. valves could be opening at the same time!. I'd examine the heads thoroughly. Cuz from what ive been hearing of ur situations and setup these last several months, it doesnt sound like u mis-match any parts.
Old Apr 18, 2005 | 05:03 PM
StangTangGT's Avatar
StangTangGT
Damn dan your still havein problems with the stang huh? that blows well best of luck to ya, oh hey whats up Joe?
Old Apr 18, 2005 | 07:42 PM
luckythirteen13's Avatar
luckythirteen13
[sm=hail.gif]AFR [sm=icon_rock.gif]
[sm=boosign.gif] Edelbrock
lol, j/k you must have missed something. those heads should have added plenty of power
Old Apr 18, 2005 | 09:02 PM
Dan89lx's Avatar
Dan89lx
i paid a professional engine builder to put the heads on and adjust everything. my problem is either in the fuel injectio b.s. or the ignition. i suspect the pickup coil so i am going to change the distributor cause i know this one i got from my buddy is good. i am also going to put in an A9P computer and see what kind of diffrence that makes. I am a nats *** from ripping the fuel injection off and carbing it, but not until I try a few more things. The car is just plain SICK !!!!!!! I will get it right eventually, if i have to carb it then so be it.
Old Apr 18, 2005 | 09:04 PM
Dan89lx's Avatar
Dan89lx
oh and trust me, if I had bought new heads- they would have been AFR. I got these edelbrock performers barely used with rockers for $650 so I couldnt turn em down. AFR's would have gave about 15 more horsepower so I figured I could save $700 and be 15hp less. a little home porting and these will be just as good as AFR's.
Old Apr 18, 2005 | 09:09 PM
grabbem88's Avatar
grabbem88
got picks of the nat's ***???[&:] j/k....let me help ya....what was your timing???if it was 14* then you should be ok
what lbs are your injectors???and i need your fuel pressure too...yeah afr's are good that's what i traded my rpm's for still
the edelbrach's should of helped....to me your state of tune is way off.
Old Apr 18, 2005 | 09:11 PM
86HOGT's Avatar
86HOGT
Dan, do you have a chip or programmer? You've probably hit the end of even the MAF computer's abilities without a chip/tune.
