Yet Another Disappointment
Old Apr 19, 2005 | 10:06 AM
  #21
86HOGT's Avatar
86HOGT
Default RE: Yet Another Disappointment
That little "chip" you call, is not a chip, it's the SPOUT connector. All it does is break the contact from the PCM to the distributor to take computer advance out of the picture, and run the car off of base timing at which you set with a timing light and turning the distributor. Dan, it sounds more like you need to figure that out before going any further.
Old Apr 19, 2005 | 07:02 PM
  #22
Demon_Mustang's Avatar
Demon_Mustang
Make sure they resurfaced the bottom of the heads before putting them in to make sure there are no leaks.
Old Apr 19, 2005 | 07:54 PM
  #23
88PatrolCar's Avatar
88PatrolCar
ORIGINAL: Dan89lx
please tell me in detail how to set the distributor and timing cause i am gonna pull mine and change it, then set the timing with a light. i am clueless on timing. should i leave the chip in/out while timing the car. ???????
Before you pull the old distributer out, take the cap off and mark on the engine were the rotor and the TFI is pointing. Pull the distributor out and set the new one in, line the rotor and TFI up with the reference points you made. Put the cap and wires on, unplug the spout, start car, set the timing were you want it 10* is factory but you probly want about 14*, plug spout back in and timing should advance close to another 10*
2007CalSpec
Dec 13, 2020 11:42 AM
Sep 16, 2015 07:53 PM
ryland
Sep 13, 2015 12:35 PM
squishbang
Sep 7, 2015 07:57 PM
Chosen One
Apr 5, 2005 11:20 PM
