how to replace the trans fluid?
Old Apr 19, 2005 | 01:10 PM
cleancutdesigns's Avatar
cleancutdesigns
Default how to replace the trans fluid?
I purchased a 01 bullit and the shifting is a little notchy, I have read people having good luck with royal purple man. trans fluid filled at 3.2 quarts. I have never done trans changes or never had a mustang.. so just curious if someone could give me a run through of how to change the trans fluid. I am mechanically inclined.. just want to make sure I do it right.
Old Apr 19, 2005 | 01:46 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: how to replace the trans fluid?
getting it out is easy. There is a drain plug. Getting it back in is more diffficult but if you go pick up a cheap plastic squeeze "pump" for $20, it's easy enough.
Some guys fill it up by taking the shifter off.
Old Apr 19, 2005 | 01:49 PM
Djs94stang's Avatar
Djs94stang
I use a 3 or 4 ft piec of hose with funnel and fill it from the engine compartment. I put a pan under the trans since when it's full (to the plug) it will drip out. From dead empty you can pre-measure what goes in, roughly, since you can look up the capacity to give you an idea.
Old Apr 19, 2005 | 02:31 PM
MikeHawke's Avatar
MikeHawke
ORIGINAL: Djs94stang
why didn't I think of that?[8D]
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
