frontend squeeking
Old May 1, 2008 | 06:43 AM
gjr86hd's Avatar
gjr86hd
Default frontend squeeking
The front end squeeks when driving, braking, turning, and/or if you push on the front. Does this sound like a spring or bushing problem or anything else?
Old May 1, 2008 | 11:11 AM
m260gt's Avatar
m260gt
Default RE: frontend squeeking
mine does it to. but havent had the chance to post yet. kind of annoying.
Old May 2, 2008 | 06:25 AM
Jfsram's Avatar
Jfsram
This could be the ball joints.
Old May 3, 2008 | 09:36 PM
ewgoetz's Avatar
ewgoetz
Jack it up on some jack stands and check for anything loose. it can be a ball joint or bushings or your struts. Best bet is to look in a sunday flyer and look for a place that does free checks. have them put it on a lift and check it all out.
Old May 6, 2008 | 08:32 AM
Jfsram's Avatar
Jfsram
The problem with checking it on jackstands is the ball joint is not loaded like when it's on the ground. The wear area in the socket my be tight when the suspension is drooping.
By the way. Ball joints are a common wear item on Mustangs and it's pretty ugly when they fail.
Old May 6, 2008 | 02:25 PM
jim135666's Avatar
jim135666
Im having the same problem on my 00' GT, i seen in alot of posts (this problem). I was told many things but i think its either the balljoint or some bushing. Im still wondering what it is and its becomming increasingly more of a concern. The only difference is the squeeking stops when im on the brakes.
Old May 6, 2008 | 03:14 PM
ewgoetz's Avatar
ewgoetz
when u put it on jack stands, put the jacks under the control arms.
fastmofo
Apr 9, 2006 10:38 PM
BlueDemon
Jul 2, 2005 01:18 PM
2004 GT RagTop
Feb 14, 2005 02:27 PM
stangster666
Dec 6, 2004 08:34 PM
2004 GT RagTop
Nov 26, 2004 05:33 PM
