factory timing setting??
Old May 2, 2008 | 02:19 PM
88fox50's Avatar
88fox50
Default factory timing setting??
im sure this has been said a few tomes over here ...but i have an 88 5.0 and i wanted to find out the factory timing ...is it 10*? please help mine is is set at like almost 14and its runnig crappy...thanks.
btw ...i just bought it and trying to work out the kinks...thx again
Old May 2, 2008 | 03:57 PM
gjr86hd's Avatar
gjr86hd
Default RE: factory timing setting??
The stock setting is 8-10. It was set to 14 to give it more pick up and pull more rpm's. I would keep it at 14 only if you are going to use 93 octane. Try setting it to 12 otherwise.
Old May 5, 2008 | 10:30 AM
Jfsram's Avatar
Jfsram
Your car is not running crappy because of the ignition timing.
10 or 14 deg will not change the running quality. Look elsewhere.
As for 14 deg and 93 octane. If it's not detonating, don't waste your money.
drfister
May 3, 2018 10:38 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Chris07GT
Sep 1, 2015 07:11 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
