Interior panel removal?
Old May 4, 2008 | 11:30 AM
pbMaxLax44's Avatar
pbMaxLax44
Default Interior panel removal?
I have a 2000 V6 convertible and wanted to paint a few interior panels. How do I remove the door panels around the locks/windows? It seems like there is a little space to fit a flathead in to wedge out but I want to make sure. Also, the trim around the A/C and radio, then the trim around the shifter. Thanks. =)
Old May 4, 2008 | 12:10 PM
ryan1994mustang's Avatar
ryan1994mustang
Default RE: Interior panel removal?
the plastic panel that holds the window switches in can be popped out. behind that are 2 screws that need to be taken out. then you need to take the mach speaker out of the top corner of the door(if you have mach system). the cover for that just pops off and there is a hole with a screw in it, then it just slides up and disconnects. after this, you should be able to just lift the whole door panel up and it should just pull right off.
Old May 4, 2008 | 11:08 PM
pbMaxLax44's Avatar
pbMaxLax44
What about the trim around the shifter and the trim around the AC and radio?
Old May 5, 2008 | 03:24 PM
Red02's Avatar
Red02
trim around the shifter/radio also just pops off. but start with the cover around the shifter. just held in my snap clips
Old May 8, 2008 | 04:22 PM
pbMaxLax44's Avatar
pbMaxLax44
ORIGINAL: Red02
Trim around the radio definitely does not just pop off. It had two screws in it and it still won't come off. Do I need to pull the radio/CD player out(I have the two single din version)?
Old May 8, 2008 | 05:10 PM
ponysnake99's Avatar
ponysnake99
Theres a small bolt anchoring the center to the dash, take the two radio units out and you should see it.
Old May 8, 2008 | 06:11 PM
Red02's Avatar
Red02
sorry for the false information, mine just came right off. but now that u mention it i think it has 2 small screws at the bottom of the cover, then it pops off,, its been a while. sorry
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
