Having trouble removing hood
Old Apr 23, 2005 | 02:16 PM
frank28's Avatar
frank28
Default Having trouble removing hood
Does anyone have any tips for doing this? I have a 2002 Ford Mustang that I'm trying to remove the hood from. When I got to the bolts and tried to loosen them, they wouldn't budge. Next to stripping the bolts, I can't think what tool I should use or what I might be doing wrong.
Thanks,
Trey
Old Apr 23, 2005 | 07:11 PM
86gt5.0HO's Avatar
86gt5.0HO
Default RE: Having trouble removing hood
They probably have lock tight on them (the red stuff). you will have to heat around them with a torch. Are you repainting the hood? If you are bakeing the paint off of it won't matter, but if you don't want to hurt the finish on the hood have an assistand continuously pour water onto the top of the hood in the area where you are heating. It doesn't take much heat to unlock the lock tight, then find a good socket to fit and crank 'em lose. Good Luck!
Rick Nagel
Old Apr 25, 2005 | 12:31 PM
frank28's Avatar
frank28
That's great advice. Thanks man!
Old Apr 25, 2005 | 01:03 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: 86gt5.0HO
Rick Nagel
The hood is fiberglass on his car dude. I'd stay away from that with a torch.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Dathan
Oct 5, 2015 05:52 AM
