SOMETHING GOT INTO THE INTAKE
Old May 12, 2008 | 08:17 PM
mstang99's Avatar
mstang99
Default SOMETHING GOT INTO THE INTAKE
I was cleaning the throttle body with a cleaner that have that little red straw to spray on the throttle plates and inside of it and it got into the intake, I already tried to suck it out with a vacuum cleaner but it didn´t came out. What can I do? Will that little thing hurt my engine if I leave it in there? Please HELP ME!!
Old May 13, 2008 | 09:12 AM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
Default RE: SOMETHING GOT INTO THE INTAKE
umm yes... if it gets sucked through ur intake into the head or even past the head into a cylinder your motor is done, you need to pull your throttle body off and then the space and try to fish it out, if not you need to pull your upper intake off and blow air all through it and hope it flys out, if not you will need to pull your lower intake [&o]and hope you see it, if not man, your gonna be **** out of luck if it gets in a cylinder
Old May 13, 2008 | 12:58 PM
mstang99's Avatar
mstang99
thanks, I already got it out, I took the tb off and found it like 4-5 inches from the entrance, it wasn´t hard at all to take it out, thankfully I haven´t to pull the intake off, now I need a new gasket, I will be doing that tonight. thanks again
ORIGINAL: sYckmYnded
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
