Testing Fuel Pump Question.
Old May 13, 2008 | 04:49 PM
dreamer1uk's Avatar
dreamer1uk
Default Testing Fuel Pump Question.
Hi all,
I have a quick question. What is the best way to test and hot wire a fuel pump in a 2.3 LX Convertible? Its the DIS ignition system.
Ijust need to use a paper clip in the Fuel Pump Test point to the Computer Test Ground point on the ECC test connector right? or what is another logical and safe way?
The reason im trying to test the pump is because i have a no start condition and im trying to rule out the fuel pump.
Thanks!
Old May 14, 2008 | 01:09 AM
Stepman's Avatar
Stepman
Default RE: Testing Fuel Pump Question.
When you turn the key on you should be able to hear it run for a few seconds. You can poke the schrader valve to see if fuel is present also.
Old May 14, 2008 | 04:13 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
Im not hearing the fuel pump ay all when the key is on the "On" position.
I was wondering if its possible to wire the pump to a 12v source thats all.
Thanks.
1TUFF302
Nov 5, 2015 04:02 PM
9550
Oct 26, 2015 05:01 PM
pimp2303
Sep 17, 2015 08:45 PM
SteelerNation82
Sep 16, 2015 07:11 AM
jaiidutch
Sep 14, 2015 10:29 AM
