wheel spacers throwing off front end?
Old May 16, 2008 | 09:33 AM
boostanggt's Avatar
boostanggt
Default wheel spacers throwing off front end?
I have an 04 GT with the o4 cobra wheels. The problem came whenI put on the strange coilovers. The tire rubs the adjustment screw. I through on a set of 7/32 wheel spacers and now it seems that my wheel balancing is WAY off. It's barely drivable on the highway. Is this a common problem or is it my wheel itself off balance?
Old May 16, 2008 | 10:58 AM
GreyStang's Avatar
GreyStang
Default RE: wheel spacers throwing off front end?
So, you're putting wheel spacers on the FRONT wheels? Good luck with that. A lot of people get wobbles & bad handling when doing that.
It would seem wheel spacers are best left on the rear wheels only.
Old May 17, 2008 | 09:24 AM
boostanggt's Avatar
boostanggt
my tires rub the coilovers without them..
Old May 17, 2008 | 10:52 AM
GreyStang's Avatar
GreyStang
Then you're gonna have to get rims with different offsets or convert your suspension back to stock.
Maybe if you took your car to a tire shop with the spacers attached they might be able to balance it for you..
Old May 17, 2008 | 05:34 PM
boostanggt's Avatar
boostanggt
yeah thats not gonna happen. has anyone else had a problem with spacers?
Old May 18, 2008 | 11:04 PM
Jfsram's Avatar
Jfsram
I also am against the use of wheel spacers but if you must.
Remove them. Clean the rotor to wheel surface with a wire brush. Do the same for both sides of the wheel spacer and the inside of the rim.
Any flaw in the surface, be it dirt or tolerance in the wheel spacer is amplified at the tread. Remember trigonometry. A 0.040" flake of rust near the hub can make the treadsurface a quarter inch out.
Just raise the front and spin the tires. Watch the tread surface for runout.
BTW. Spacers on the rear can have the same issues too but you will not feel the shaking as much in the rear. Even though it's still there.
Old May 19, 2008 | 09:00 AM
shaun8850's Avatar
shaun8850
I have a 88 gt, I just put spacers on the front and I having a thumping when I first take off in the morning... It seems to go away after tires warm up. The tires are new along with rims. Would that be tires or could it still be a similar issue with spacers?
Old May 19, 2008 | 01:39 PM
shaun8850's Avatar
shaun8850
HEY CHECK OUT THIS THREAD! HELPED ME ALOT!
https://mustangforums.com/m_1499936/tm.htm
Then if you need some get the plastic ones!
http://www.1010tires.com/hubrings.as...FQ0BswodlQ3foA
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
svastano
25
Jul 16, 2016 01:20 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
mikecaputo
Aug 22, 2015 10:58 AM
