Squeak Squeak Squeak
Old May 21, 2008 | 11:40 AM
akp20032004's Avatar
akp20032004
Default Squeak Squeak Squeak
I have a squeak and I think, and I don't know for sure, but i THINK that it's coming from the front. Brakes are not worn down I just checked them yesterday. Every time i accelerate It squeaks and when I slow down to squeaks. Not a constant squeak but a squeak squeak squeak squeak squeak. But it only does when I am stopping or just starting to go.
Old May 21, 2008 | 12:01 PM
1990NOS!'s Avatar
1990NOS!
Default RE: Squeak Squeak Squeak
what about when you hit bumps?
Have someone ride beside you and listen for.... i had the same problem before, even on new brakes....And yep the brakes were causing the squeak, so the shop turned the rotors... And threw in some new pads.... Just check it and see.
Also have you checked your belts?-- any fluids on your cerpentine belt? or any leaks anywhere?
Old May 22, 2008 | 01:06 AM
briansgonnawin's Avatar
briansgonnawin
does it happen when you start the car? maybe your belt is slipping
Old May 22, 2008 | 08:01 AM
akp20032004
It's not when I start in, just slowing and accelerating.
Old May 22, 2008 | 10:53 AM
Sucksatlife's Avatar
Sucksatlife
I ♥ Acer
are you a ****ing squirrel
Old May 23, 2008 | 11:10 AM
Mjaga251's Avatar
Mjaga251
ORIGINAL: Sucksatlife
what?[sm=headbang.gif]
Old May 23, 2008 | 07:53 PM
88blk5.0's Avatar
88blk5.0
Ball joint.
Old May 24, 2008 | 11:21 AM
akp20032004
ORIGINAL: 88blk5.0
Ball joint.
I'll probably replace them and see if that's it. If so your a genius!! I would've never thought of that.
istambay1217
Jun 30, 2018 12:31 PM
marcuslee842
Jun 4, 2005 05:02 PM
StngPshr03
Apr 26, 2005 06:42 PM
Cedarkill
Sep 14, 2004 08:35 PM
EmptyEvergreen
Sep 3, 2004 03:40 AM
