2002 Mustang will not run?
Old Apr 27, 2005 | 01:17 AM
MacIntyreMustang's Avatar
MacIntyreMustang
Default 2002 Mustang will not run?
Hello, I am working on a 2002 Mustang 3.8LV6. It was hit in the front right and busted the rad. The serpentine belt also fell off somehow. I can not get the car to run. It will start and miss and sputter and go on as long as you pump the gas pedal, then die. It acts like it is flooded but the plugs look good, and I have tried to start it a few times this month. I put some fuel conditioner in and that did not help. The fuel shut off switch is not tripped. Does anyone have any ideas? Thank you.
Old Apr 27, 2005 | 01:39 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: 2002 Mustang will not run?
Not the safety switch eh?
Old Apr 27, 2005 | 12:08 PM
IownaMustangNow's Avatar
IownaMustangNow
i woulda thoguht it was the safety switch too...happened to my thunderbird when i got hit...dunno, but good luck ne ways
Old Apr 27, 2005 | 01:13 PM
PipsBlackStang's Avatar
PipsBlackStang
I remember on mine that would happen, and it had to do with the EGR valve and being stuck at wide open. Check the vacuum on it. It will probably have a high pitched sound with it but its not too loud.
Old Apr 27, 2005 | 11:57 PM
stang Gt's Avatar
stang Gt
If the air bags deployed I bet the computer has to be reset the saftey switch had to have been activated. It could be that the computer got messed up and your timing is off to. Call your local ford dealer service department and tell them what you told us. They will probably want you to bring it in for a diagnostic check. A cost of about eighty bucks to solve the mistery.
01blackgtconv
Aug 14, 2015 04:50 PM
cody.hoeppner
Aug 12, 2015 06:39 AM
daytooday
Aug 11, 2015 09:22 AM
Danwiel
Aug 11, 2015 06:49 AM
89blueslug
Aug 10, 2015 07:20 AM
